Old 14-Jun-2014, 3:55 PM   #11
Stereocraig
Originally Posted by Bigbear View Post
Not to dismiss any of the suggestions but I'm still puzzled re the water getting in to the outside connections. I also have a DTV 18" dish with dual LNB that each of the cables have similar connections with out boots and I have no issues with their signals.
Can I " dry " out connections with WD 40?
Water can and will "Wick" into the coax itself.
The only way a WD product would work, would be if you could chase the water out the other end.
Heat, UV and extreme cold, can do strange things.
