Old 14-Jun-2014, 2:07 PM   #2
The tvfool report is showing 15 feet antenna height above ground.
Do Not Delete the tvfool report that is showing antenna height of 15 feet above ground.
The Madison Tv Stations/Channels are easy to receive.
The Milwaukee Tv Stations/Channels are Weaker Signal Strength , are ~60~ Plus Miles Distant , Have 2 Edge Path Obstructions=Hills-Mountains.
To see if Signal Strengths Improve and Edge Path Obstructions Improve with Higher Antenna Heights.
Please make and post 2 more tvfool reports with exact address and antenna heights of 25 and 40 feet above ground.
