As a Test of reception to the North.
The HBU44 antenna can be aimed by hand to the North at about 9 degree magnetic compass direction.
Rescan for Channels.
Most Digital Broadcast Tv Tuners have a , Signal Strength Meter , and some also have a , Signal Quality Meter.
Adjust antenna aim for best reception.
When scanning for channels.
Go into the Tv Setup Menu and select and channel scan for.
Channel Scan for the , OTA=Over The Air - Antenna Channels , ATSC-Digital Broadcast Tv Antenna Stations/Channels.
DO NOT Channel Scan for Cable Tv Channels.
DO NOT Channel Scan for Only Analog Broadcast Tv Stations/Channels.
Reason: Clarify information and typos.
