Old 14-Jun-2014, 3:13 AM   #3
Antenna System #1.
For Improved Reception of the North West Group of Digital Broadcast Tv Stations/Channels.
Install , DB8e , Current UHF Channels 14 thru 51 antenna aimed at about 308 degree magnetic compass direction.
And install the , Y10-7-13 VHF high band antenna aimed at about 308 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a cell phone , tablet and etc. compass.
Connect the , DB8e and Y10-7-13 antennas together with a ,
http://www.antennacraft.net.
10G221 preamp.
For 1 Tv connect use No splitter.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
To add the reception of and or improve the reception of.
KHIZ-LD , Real VHF low band digital channel 2 , ZUUS Country Music.
KRVD-LP , Real VHF low band digital channel 5 , Religion.
Connect a , http://www.antennacraft.net.
Y5-2-6 , VHF low band channels 2 thru 6 antenna.
To the Y10-7-13 VHf high band channels antenna with a , HLSJ = High band/Low band - Separator/Joiner.
http://www.hollandelectronics.com/ca...-Diplexers.pdf.
______________________________________________________
Antenna System #2.
For Improved Reception of , KVCR-DT , Real UHF band digital channel 26 , PBS Networks.
Aim the 91XG UHF band digital channels 14 thru 51 antenna at about 65 degree magnetic compass direction.
Connect the , CM7777 preamp to the 91XG antenna.
The 91XG antenna system is a Completely Separate Antenna System , Separate splitters , Separate coaxes , All parts Separate from antenna system #1.
A , Separate Tuner / Tuner Recorder , is used to receive KVCR-DtT - PBS , at each Tv location.
http://www.epvision.com
