Old 14-Jun-2014, 1:14 AM   #1
ignatz13
Inconsistent reception
I'm about to go nuts trying to figure out how to get the best reception fairly consistently. Most of the time, I can receive 35 channels...14 from Arkansas towers and the rest from towers outside of Tulsa, OK. I frequently receive Oklahoma City and Little Rock channels at night. I am mainly interested in the Tulsa stations which I receive great most of the time.
The problem is my reception drops to anywhere between 14 to 20 channels several times during 24 hours. I have a DB8 antenna at 30' and a homemade McLapp M4 antenna 4 ' above it. I added the M4 so I could receive Tulsa Channel 8 KTUL. Both antennas are connected to a Channel Master CM-7778 preamp through a Channel Master antenna combiner. The cable lengths are the same from both antennas going to the preamp and the coax to a Vizio tv is about 40'. I've had this problem when using either of the antennas by themselves and when I was using the CM-7777 preamp which
was too strong for my area. Without a preamp, I receive 14 Arkansas channels and 3 from Oklahoma.
I understand that tropospheric ducting may play a big part during the day, but the same thing happens at night and I have to turn the antenna and rescan even though the antenna hasn't moved. Also I noticed that turning the mast a 1/4 or a 1/2 inch will either cause me to lose or gain channels. Should aiming the antenna(s) be that sensitive?
I could go up another 10' but don't really want to as I can only guy the mast on three sides and to the eave of the house.
My TVFool report:
http://www.tvfool.com/?option=com_wr...e1c64af9dc4f4b
Thanks for any advice.
ignatz13 is offline   Reply With Quote
