Old 13-Jun-2014, 8:51 PM   #3
Jake V
What stations do you want?
The Toronto stations are all at 144 degrees magnetic and would be pretty easy to receive (all are UHF except CFTO Ch 9). If those are sufficient, I'd try an inexpensive indoor antenna before spending more.
The Buffalo stations are at 158 & 150 degrees magnetic, but weaker. Something like a DB8e might get you most of the Buffalo UHF stations. That's quite a bit since most have sub-channels.
Others with more knowledge will comment soon.
