Old 13-Jun-2014, 2:56 PM   #2
--->For Reception of the Main Group of Tv Stations to the South East.<---
Above the Peak of the Roof install a , www.antennacraft.net.
HBU44 antenna aimed at about 115 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet , and etc. compass.
Install a , www.antennacraft.net , 10G201 preamplifier.
For 2 Tv's connected use a , Holland Electronics, HFS-2D , 2 way splitter.
For 3 Tv's connected use a , Holland Electronics, HFS-3D , 3 way splitter.
Buy the , HFS-2D , HFS-3D , splitters at , www.hollandelectronics.com , or , www.amazon.com .
www.ronard.com/909911.html
Install a , ronard(911) , 5 foot tripod antenna mount.
www.ronard.com/34424560.html
Install a , ronard(4560) , eave antenna mount.
www.ronard.com/ychim.html
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe. The price is low at about 10 dollars.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The tvfool radar plot shows the directions of reception at your location are.
South East. (The Main Group Tv Stations).
North.
West.
South West
Last edited by teleview; 16-Jun-2014 at 5:17 PM. Reason: Clarify information and typos.
