Old 13-Jun-2014, 9:44 AM   #5
Wikipedia says that WOOT-LP is Transmitting Digital UHF band channel 31 , not Analog low band channel 6.
The Networks are , Heartland , Retro TV , PBJ , Tuff Tv.
http://en.wikipedia.org/wiki/WOOT-LP.
http://en.wikipedia.org/wiki/Luken_Communications.
Recommend 2 antennas installed Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked by the roof and building in the directions of ~ East ~.
Install a Antennas Direct , DB8e Current UHF channels 14 thru 51 antenna aimed at about 75 degree magnetic compass direction.
http://www.amazon.com.
About 3 feet below the DB8e antenna on same antenna mast pipe install a .
http://www.antennacraft.net
Y10-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 85 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a , cell phone , tablet and etc. compass.
Install the , ronard(911) , 5 foot tripod antenna mount.
Install the , ronard(4560) , eave antenna mount.
Measure around the chimney and install a , ronard(2212 , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe. The price is low at about 10 dollars.
Install a , http://www.antennacraft.net.
10G221 preamplifier.
Connect the , DB8e antenna to the UHF connection of the preamp.
Connect the , Y10-7-13 antenna the VHF connection of the preamp.
For 3 Tv's connected use a , Holland Electronics , HFS-3 D , 3 way splitter.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com .
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to instal the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
