Old 13-Jun-2014, 7:04 AM   #2
I'd opt for the Antennas Direct DB8E. It has two sections that can be aimed independently. In your case, this allows you to make the antenna cover a wider range of the horizon.
I'd mount outdoors, and start with one panel facing about 115° (compass) and the other panel facing about 175°.
Try this with no amplifier to start with. If you are inclined to try an amplifier, perform this test first, http://forum.tvfool.com/showthread.php?t=13646 If the test indicates an amplifier would be helpful, I'd suggest the Channel Master CM-3410.
