Old 10-Jun-2014, 7:47 PM   #9
An HLSJ is an excellent suggestion.
The FM Filter we carry is a "full-band" filter and doesn't compromise FM suppression to save channel 6 (which it will also attenuate).
I have seen FM interference severe enough that two traps in series were needed to suppress really strong FM.
I have seen tests that show that the AD FM filter takes out only some channel 6, so it might still work in a strong channel 6 environment. I doubt that the FM attenuation of the AD filter would be sufficient in this case.
That is based on an FM fool look-up using the 4 digit latitude and longitude data in the TV fool report. It shows that 89.1 is .7 miles away and +4 dbm signal level.
