Old 9-Jun-2014, 8:44 AM   #6
In place of the CM4221HD install a CM4228HD.
Can Call the WFIE Tv Station with a Telephone and Have a Voice Conversation With the Engineering Department About the Transmission and Reception Situations of WFIE and Your Reception Situation.
http://en.wikipedia.org/wiki/WFIE.
A question.
Is , W06BD , Analog channel 6 being received??
http://en.wikipedia.org/wiki/W06BD.
As always , for Reception of Tv Stations , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and and other obstructions including you own building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to Install the Antenna/s at a Location that has the Least Amount to No Amount of Obstructions of Any Type or Kind in Directions of Reception Including Your Own Building.
Last edited by teleview; 10-Jun-2014 at 1:03 AM. Reason: Clarify information and typos.
