Old 9-Dec-2010, 9:34 PM   #1
origin8502
NE Atlanta suburb - attic installation
Total neophyte when it comes to ditching Comcast, but dagnabit I'm determined now. I've been reading for a few days, but I don't have a clear-cut definitive answer for a preferable in-attic antenna installation to feed 3 TVs on two different floors.
TVFool report: http://www.tvfool.com/?option=com_wr...81a3c23ea5d80a
I'm mostly interested in the stations listed in Green, but wouldn't balk at getting the Yellow as well. I couldn't even tell you what the stations are in Red (excepting ION and PBS) so I figure I wouldn't miss them.
As you can see I have a straight shot LOS for a majority of the wanted stations with azimuth roughly between 210-220 degrees so I'm hoping this is going to be a rather simple review.
I am inclined, if feasible, to place the antenna in my attic which sits roughly 30 feet above street level though my home resides halfway down a declined street. Our roof is wood with asphalt shingles and LOS points a bit towards brick siding on our home though antenna mount should be above the brick line. There is some aluminum ducting in the attic, but the insulation is not aluminum backed.
Could anyone provide some antenna suggestions? Signal is pretty good for my location, but I don't know if the attic placement and distance to TVs would require a pre-amplifier.
origin8502 is offline   Reply With Quote
