Jake - thanks for the response. I have tried aiming the antenna in various directions, as well as moved it around the room. In fact, I also took the antenna to another tv in my house on the second floor and aimed it in various directions with the same results.
Other channels do come and go when I move the antenna, but I simply have had no luck getting WOWK. I'm new to antennas in general, but I'm having a hard time understanding why channels with weaker signals come in fine, but that channel in particular isn't being picked up.
The room where the antenna is does primarily have walls without windows, so I'm sure there is some degree of 'blockage' in the house. However, I was not able to get the signal at a much higher position upstairs either.
