The Micron is a UHF antenna and is not particularly effective at receiving VHF channels except at short range or with very strong VHF stations. You can run the first several feet of the coax closest to the antenna horizontally and perpendicular to the direction the signals come from and it might help, but, short of adding a dedicated VHF antenna, there's not much that can be done with it.
I usually suggest upgrading to the C2V as it's both stronger on UHF and it has the VHF element that your channel 13 should need.
