Old 9-Jun-2014, 1:16 AM   #3
Jake V
Have you tried aiming the antenna in different directions to best gather the signal that reaches it? WOWK 13 (13.1) is at Magnetic 308 degrees on a compass. I'd suggest rotating the antenna in different directions and reporting your result (you will most likely gain and loose channels depending on the direction it is pointed.
Is the antenna pointing through a widow to the northwest? Are their walls blocking the signal? There are lots of potential issues with indoor antennas.
