Old 8-Jun-2014, 7:04 PM   #3
Your Reception Location has receivable Tv stations in the directions of , South , North East , West.
WHDH-TV , Real UHF Channel 42 , (virt) virtual number (7.1) , NBC and This Tv , is Low Signal Strength and has 2 Edge Path Obstructions=Hills and Mountains.
The Smallest Tv Antenna I can recommend installed Above the Peak of the Roof and aimed at about 179 degree magnetic compass direction.
Is a , http://www.antennacraft.net.
HBU33 antenna.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone , tablet and etc. compass.
A antenna system amplifier will not be required for , 1 , 2 , Tv's connected.
Here are some Above Peak of Roof antenna mounts.
Install the , ronard(911) , 5 foot tripod antenna mount.
Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com.
Here is the Federal Antenna Law that says Yes you can install the antenna Above the Peak of the Roof so as to have Reliable Reception.
http://www.fcc.gov/mb/facts/otard.html.
Return the mohu antenna or put it in the yard sale.
