Old 7-Jun-2014, 3:25 AM   #2
The situation is most likely , Multi-Path , Tv Signals Bouncing All Around Off Of Trees and Tree Leaves When Wind is Blowing and Moving Water When Wind is Blowing.
Use a More Directional Antenna that Limits the Reception of Multi-Path Tv Signals coming in at different angles to the antenna.
Install a , http://www.channelmasterstore.com.
CM4228HD antenna aimed at about 241 degree magnetic compass direction.
Do Not trust a , cell phone , tablet and etc. compass.
For Reliable Reception May Need to Have Antenna Higher.
To Better Avoid Reception That is Just Skimming Across Top Of the Moving Waves Of Water.
A Antenna System Amplifier is Not Required.
Last edited by teleview; 8-Jun-2014 at 6:28 AM. Reason: Clarify information and typos.
