Old 6-Jun-2014, 11:03 PM   #1
Brad
antenna selection help please
http://www.tvfool.com/?option=com_wr...e1c61139feca95
Hello,
Antenna help please.
If possible interested in receiving real stations 8, 13, 23, 10, and 38. Anything more would be a welcome addition.
I had an RCA ANT751R from our previous home which I installed at the new home on the existing dish roof mount 12 feet above ground. I really enjoyed removing and then sailing that dish across the yard. I am not receiving real station 23. 13
drops out seemingly dependent on wind direction and speed. About 10 miles of the distance to the transmitters is over water and most of the homes in the area single story. The antenna will be used for our one TV, so connections
are at a minimum and no splitters are involved. I estimate the total cable run at around 50 feet.
Could you recommend a few appropriate antennas choices and the optimal magnetic compass direction. I can’t get the antenna up much higher than it is, unless really necessary, not a young guy and don’t want to take a dive off the ladder.
Thank you for your time.
Brad
Brad is offline   Reply With Quote
