Old 5-Jun-2014, 9:12 PM   #10
The Current Tv Stations Channels that are Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Tvfool Channel List and Radar Plot shows the Real Channel that is being Transmitted and Received.
Tvfool Channel List shows the (virt) virtual number , the virtual numbers are Not Real Channels , even if the virtual number is the same as the Real Channel.
Tv antennas are designed to receive Real Channels.
Tv antennas are selected to receive Real Channels.
Your location has receivable Real Channels in all 3 channel bands.
However.
WHBF-TV , Real VHF low band channel 4 is also , WHBF-TV Real UHF band channel 47.
So No requirement to receive Real VHF low band channel 4.
http://en.wikipedia.org/wiki/WHBF-TV
And.
KIIN , Real VHF high band channel 12 , is also , KQIN Real UHF band channel 34.
So No requirement to receive Real channel 12.
http://en.wikipedia.org/wiki/iowa_Public_Television.
So that leaves Only UHF Real Channels to Receive in the Green and Yellow Reception Zones of the Current Plus Pending Applications Included Digital Broadcast TV Stations/Channels , Channel List and Radar Report.
So install a Antennas Direct , DB8e UHF antenna Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception , in the directions of , South South East , South West , West , North West.
Aim 1 panel of the DB8e antenna at about 190 degree magnetic compass direction.
Aim the other panel at about 287 degree magnetic compass direction.
Buy the DB8e antenna at , http://www.amazon.com.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone , tablet and etc. compass.
Install the , ronard(911) , 5 foot tripod antenna mount.
Install the , ronard(4560) , eave antenna mount.
Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , good for antenna mast pipe , low price at about 10 dollars.
When Installing the New DB8e Antenna System Start at the Beginning.
Disconnect and Remove All , Splitters , Couplers , Attenuators , Antennas , Antenna Amplifiers , Power Injectors , Power Supplies , and Etc. .
A antenna system amplifier is Not required.
Fo 1 Tv connected use No splitter.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your , Attic , Roof , Building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to Install the DB8e antenna at a Location that has the Least Amount to No Amount of Obstructions of Any Type or Kind in the Directions of Reception Including Your Own , Attic , Roof , Building.
Last edited by teleview; 8-Jun-2014 at 6:57 AM. Reason: Clarify information and typos.
