Old 5-Jun-2014, 6:52 PM   #5
timgr
Originally Posted by Aurock View Post
When shopping for an antenna, what should I look for to identify which channels it will receive? What about the amazon antenna listing indicates it's not designed to pick up channel 4?
Good question. I had to look for it.
It's in the manual. The manual says it's a high VHF and UHF antenna. Channel 4 is considered low VHF.
If you look at, say, the Antennacraft site http://www.antennacraft.net/index.html you can see which channels are within which bands.
Notice that the channel number refers to the real channel number on the TVFool reception report, not the virtual number. In this case they are essentially the same, 4 and 4.1.
