Old 5-Jun-2014, 12:02 AM   #12
Post number 8 says.
I've got 18 channels just facing my antenna southeast using the 10 foot pole next to my DTV post.
Are you now saying the antenna is 25 feet from the ground up on a
pole/poles ??
If the antenna is lower then the Peak of the Roof.
It is Ok to Test reception with the antenna above the roof.
And.
Getting the Antenna Up In The Air at a Location that has the Least Amount to No Amount of Obstructions in the Directions of Reception is the Best Way to have More Tv Stations/Channels and Reliable Reception.
What are the "obvious reasons" you do not want to put the antenna above the roof ??
Here is the Federal Antenna Law that says Yes Broadcast Tv Reception Antennas can be Installed Above The Peak of the Roof.
http://www.fcc.gov/mb/facts/otard.html.
Yes looks like the , SPLIT8MRV , splitter is Ok to use.
However know this , each time a split takes place the signal strength is
reduced.
Here is a 6 way splitter. Leviton 47690-6 , 6 way splitter.
http://www.amazon.com
Last edited by teleview; 10-Jun-2014 at 8:22 AM. Reason: Clarify information and typos.
