Old 4-Jun-2014, 6:33 PM   #11
tonyvalentine
Originally Posted by teleview View Post
Yes the CM2016 will have similar reception as the ANT751 and HBU11.
Yes the CM7721 distribution amplifier is Ok.
Installing the distribution amplifier closer to the antenna is better then further away from the antenna.
Amplifiers do not 'pull' signal through coax , amplifiers 'push' signal through coax.
The Most Important Action to take Now is get the CM2016 Antenna Up Above the Peak of the Roof so that Reception is Not , Obstructed , Impeded , Blocked by the Roof and Building in the Directions of All Directions.
As Always , Antenna Location and Antenna Aim can be Adjusted for Best Reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Signal Quality is important for reliable reception.
Thanks again for your help. As far as signal quality goes would you say 68% is reliable or will I lose these signals more frequently? I am hesitant to put the antenna on the roof for the obvious reasons. Also I don't believe it will clear the trees enough to make a big enough difference between the roof and 25' pole length on the ground. Once again I'm a novice and not suggesting you're recommendations are not valid I just want to be sure it's worth the trouble is all.
tonyvalentine is offline   Reply With Quote
