Old 1-Jun-2014, 9:56 PM   #5
For reception of the Canada Tv Stations only.
Install a , http://www.antennacraft.net.
HBU11K antenna Above the Peak of the Roof aimed at about 105 degree magnetic compass direction.
The Canada Tv Stations are to the , East , South East , South West.
A antenna system amplifier will most likely not be required for , 1 , 2 , 3 , Tv's connected.
However if the weaker signal strength Tv stations/channels in the Yellow reception zone of the tvfool report are weak signal strength reception at the Tv locations , install a , http://www.winegarddirect.com , LNA-100 Boost amplifier before the splitter.
_______________________________________________________________________________
To Test for reception of USA Tv station KNNR , FOX.
And also receive the Canada Tv Stations.
USA Tv Station KNNR , Real VHF High Band Channel 12 FOX , is Very Weak Signal Strength.
For reception of KNRR Fox and the Stronger Signal Strength Canada Tv Stations.
CHMI-DT , Real VHF High Band Channel 13 CITY TV.
CKY-DT , Real VHF High Band Channel 7 CTV.
Above the Peak of the Roof in such a manner that the , Roof and Building are not , Obstructing , Impeding , Blocking , Reception in the Directions of , South , South East , South West.
Y10-7-13 , VHF High Band Channels 7 thru 13 antenna.
Aimed at about 164 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone , tablet etc. compass.
For reception of the , Canada UHF Channels Tv Stations to , East South East.
Also install a , Antennas Direct , Clear Stream 4 , Current UHF Channels 14 thru 51 Antenna.
Aim the the CS4 antenna at about 90 degree magnetic compass direction.
Install the CS4 antenna about 3 feet above the Y10-7-13 antenna on the same antenna mast pipe.
Install a , RCA TVPRAMP-1R preamp.
Connect the , Y10-7-13 antenna to the VHF connection on the preamp.
Connect the , CS4 antenna to the UHF connection on the preamp.
The , Y10-7-13 and CS4 antennas are Strong and Sturdy antennas that will last a long time in high winds , snow and ice.
Here are some Above the Peak of the Roof antenna mounts.
Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html.
Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com.
Lowes and Home Depot of Canada has.
10 foot 6 inch , 1 and 3/8 inch diameter.
Or , 10 foot 3 inch , 1 and 1/4 inch.
TOP RAIL , chain link fence , PIPE , that make good antenna mast pipe.
http://www.tdlcanada.ca.
http://www.saveandreplay.com.
http://www.hollandelectronics.com.
http://www.antennasdirect.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to Install the Antennas at a Location that has the Least Amount to No Amount of Obstructions of Any Type or Kind in the Directions of Reception Including Your Own Roof and Building.
Last edited by teleview; 3-Jun-2014 at 1:48 AM. Reason: Clarify information and typos.
