You will need something that picks up VHF as 14 and below is VHF, vs UHF. I presume your antenna is UHF only, specs are pretty silent. I'll look some more to see if yours is UHF only.
RCA Ant 751, small and easily mounted on the J mount. But I'd like to here what others say in regards to the metal roof. Signals are strong, but multi-path could be an issue. Possible more detail might be needed.
There are some omni's out there too such as from Channel Master - but I have no experience with those.
