Remove the dish and the arm that holds its LNB, then mount the antenna directly to the original dish J-mount if that location allows you a clear and unobstructed view to the NNW.
Eliminate the pre-amplifier, it should be unneeded.
Re-use only the coaxial cable (and possibly the mount) from the satellite installation. Be absolutely certain you have removed any and all splitters, diplexers, multi-switches, and the like should there have been any in use.
If WNBW still won't come in after that, you're going to need to figure out why - most likely will be electrical interference.
