Old 31-May-2014, 7:53 AM   #4
The Broadcast Tv Stations/Channels in the Green and Yellow reception zones of Current Plus Pending Applications Included TvFool Report are strong signal strength.
No antenna system amplifier is required.
Install the Antenna Above the Peak of the Roof in Such a Manner that the Roof and Building are Not , Obstructing , Impeding , Blocking , ---> Reception in the Directions of , North West , North , North East , South East.
Aim the antenna at about 341 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone , tablet and etc. compass.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to Install Antenna at a Location that has the Least Amount to No Amount of Obstructions of Any Type or Kind in the Directions of Reception Including Your Own Roof and Building.
Also Move the Antenna Away From Electric and Electronic Devices that are Inside and Outside of Attic.
As a Test to Prove Reception.
Disconnect and remove All parts of the preamplifier , disconnect and remove the preamp unit , disconnect and remove the power injector/power supply units.
Install a New matching transformer (balun) to the antenna.
Connect a NEW Continues Length of standard coax that has , one foil shied and one braid shield , do not use quad shield.
Run the NEW Continues Length of coax from the matching transformer through a open door or window direct to one Tv.
No couplers , No splitters , No etc. .
Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do a Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
Now reconnect All parts of the Preamp and Rescan for Channels.
What is reception like now??
Last edited by teleview; 7-Jun-2014 at 9:40 PM. Reason: Clarify information and typos.
