Old 31-May-2014, 12:45 AM   #2
Flint Ridge
Junior Member Wannabe
Ok, a few quick points. You need to get the antenna parallel to mother earth and pointed 335 degrees. Remove pre-amp, hopefully you have enough cable to direct connect it. Heck if not bring the antenna down, hook it direct, point, rescan and see what you have. Amp may not be needed. If so, amp is way too far away. <6' is normal distance.
You will get much better info shortly. If you have a known good coax, then bypass all existing straight from antenna to tv. And I am with you Football is a priority here too.
