Old 29-May-2014, 9:58 PM   #6
Above the Peak of the Roof install the Y10-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 293 degree magnetic compass direction..
And install the DB8e , UHF band channels 14 thru 51 antenna about 3 feet above the Y10-7-13 antenna on the same mast pipe.
Aim the DB8e antenna at about 308 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone , tablet and etc compass.
Here is a 10 foot tripod roof antenna mount.
http://www.ronard.com/712.html.
Install the , ronard(712-50-10)
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast , the cost is low at about 10 dollars.
RCA , TVPRAMP1R , Preamp.
Connect the , Y10-7-13 antenna to the VHF connection of the preamp.
Connect the , DB8e antenna to the UHF connection of the preamp.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Last edited by teleview; 6-Jun-2014 at 6:58 AM. Reason: Clarify information and typos.
