The tvfool report is antenna height of 20 feet above ground.
Do not delete the tvfool report that is 20 feet above ground and make and post
2 more tvfool reports , 40 and 60 feet above ground , so as to see if signal
strengths improve of the weak signal strength Tv stations in the Red reception
zone , and the 2 Edge Path Obstructions=hills/mountains , improve to 1 Edge or
even LOS=Line Of Sight , reception.
