Old 26-May-2014, 6:41 PM   #7
How far down the channel list of the , Digital Current Plus Applications Included Broadcast Tv Stations Channel List is Reliable Reception Happening.
Is WPXD-TV , Real UHF band channel 50 , (virt) virtual number (31) ION Networks , received??
Is CBET-DT , Real VHF high band channel 9 , (virt) virtual number (9) The CBC , received??
http://en.wikipedia.org/wiki/CBET-DT
As a Test of reception.
If the HBU44 antenna is aimed at about , 106 degree magnetic compass direction.
And rescan for channels.
Are these Canada Digital Broadcast Tv Stations/Channels received??
CFPL-DT , Real VHF high band channel 10 , (virt) virtual number (10) CTV TWO , received.
http://en.wikipedia.org/wiki/CFPL-DT.
CHCH-DT , Real VHF high band channel 51 , (virt) virtual number (51) IND. , received??
http://en.wikipedia.org/wiki/CHCH-DT.
CIII-DT , Real UHF band channel 29 , (virt) virtual number (29) Golbal , received??
http://en.wikipedia.org/wiki/CIII-DT.
As always , a Tv antenna is installed and aimed at a location that has the least amount to no amount of obstructions in the directions of reception for reliable reception.
As always , the antenna aim can be adjusted for best reception.
Most Digital Tv's have a , Signal Strength Meter , and some Digital Tv's also have a , Signal Quality Meter.
Signal Quality is Important for Reliable Reception.
If are received.
A second Separate HBU44 antenna and antenna system can be installed.
A Tuner / Tuner Recorder , is installed at each location that is to receive the Canada Tv Stations/Channels that are to the , East South East.
http://www.epvision.com.
Last edited by teleview; 28-May-2014 at 8:21 AM. Reason: Clarify information and typos.
