Thanks for the reply. I think you're right about the amplifier in the Lava antenna. I have to turn the amplifier all the way down for best performance, but even then, reception is as described above.
Why is this only affecting channel 9? According to the map, the stations I want to receive are all the same distance and direction. Why do the rest come in perfectly?
Also, what antenna would you recommend? I prefer something compact if possible.
