Old 25-May-2014, 6:49 PM   #5
Different antenna height might receive Many More Tv Stations and Tv Networks.
It is --->Very Important<-- to use a Exact Address , Make and Post those lower antenna height Tvfool Reports.
A antenna height above ground that is lower then 100 feet above ground might provide reliable reception of.
WHSV-TV , Real UHF Band Channel 42.
For reception of , ABC , FOX , MyNetwork , Me-Tv , CBS .
http://www.rabbitears.info/market.ph...callsign=25042.
I did my best to estimate the reception location , and then run reports at 100 feet above ground and lower antenna heights above ground.
It looks promising , however can not be sure , need to see those exact location - antenna heights Tvfool reports.
To make Exact location Tvfool reports.
Go to the tvfool home page.
Click on , >>Start MAPS<<.
Enter a address and or zip code.
Click on , (Map this) button.
Move the pointer to the Exact reception location.
Enter in the antenna height.
Click on the (Make Radar Plot >>) button.
Last edited by teleview; 26-May-2014 at 7:12 PM. Reason: Clarify information and typos.
