Old 25-May-2014, 2:11 PM   #3
BlueMountain
Yes the antenna is on a mast running through the north side decking. I just measured and sadly have discovered the antenna is only 30 ft off the ground
This is the 30ft report:
http://www.tvfool.com/?option=com_wr...e1c604647e9931
With the newfound discovery that my measurement estimating skills need polishing it doesn't make sense for me to run any additional reports, until we can figure out another antenna system.
I'd be concerned about using a chimney tripod or chimney bracket system because the antenna seems to be pretty large and the higher up it flies the more secured it would need.
Should we consider a newer antenna? I've read lots of forum posts about all the different antennas and it seems pretty confusing.
We also bought, but haven't installed yet, a Radio Shack signal High Gain Signal Amplifier. What are the comments/thoughts about the success of using a system like that, with our current situation?
BlueMountain is offline   Reply With Quote
