You have posted tvfool reports with antenna heights of 50 and 100 feet above ground.
Can you get the antenna to those heights??
And if so , is the antenna on a tower??
A typical 1 story house will put the antenna at about 25 feet above ground with the antenna install on a tripod antenna mount above the peak of the roof.
At the 100 foot antenna height above ground , their are no hills/mountains blocking reception and no signal strength problems.
To see what reception is like at lower antenna heights please make and post tvfool reports with antenna
heights of , 90 , 80 , 70 , 60 , and 25 , feet antenna heights above ground.
Reason: Clarify information and typos.
