Old 23-May-2014, 12:45 AM   #32
The ANT-751R would do well... Your reception conditions are excellent. If your conditions were challenging in some way I could understand the hesitation, but you've got it so easy... I think it's time to hang some metal in the air.
I've got an HW-150PVR here... I'll have to set it up with a SiliconDust HDHR on the output to see if there's some loop through loss. I suspect that's going to be the case, but even so, your situation does not look like 3 or 4 dB of insertion loss will be worth worrying about. I'll let you know what my test shows...
