Old 21-May-2014, 10:49 PM   #7
Damon459
Ok I know you guy's have covered this but I have a question. I'm using two AntennaCraft Y10-7-13's and a jointenna set for channel 11. Here's the issue with the insertion loss of the jointenna channel 11 barely comes in at all. I tried aiming then in the exact same direction and I get signal but it's unwatchable. So I emailed Antennacraft and told me the minimum distance between antennas should be 1/2 wave length or 32 inches, I went a full wave length or 64 inches. Now he mentioned something I don't understand in the lingo, he said "The most efficient way to stack this type of antenna is to run parallel lines (or 300 ohm twin-lead) between the two antennas and feed from the midpoint. Doing so, eliminates the loss introduced by the antenna coupler." what does this mean? I will tell you might setup is as follows, antenna at top of the pole and antenna at near bottom of pole with jointenna in the middle connecting two identical pieces of RG6 dual shielded. The out to tv line then goes down to an RCV tv Preamp on the VHF side. From there it goes around me trailer to the opposite side. I had to do this because the antenna just won't lock a signal on the other side of the house (odd I think but there you are). I also want to add a splitter so I can feed another tv in my guest room. Please go easy on me I'm still a newbie on all this ota stuff. Oh and I should add I need the preamp because I'm running all this to a 4 turner tivo roamio. Here is my tv fool report. http://www.tvfool.com/?option=com_wr...46aeda0dd01005 I'm getting KPAX-DT without issue, I'm trying to get KUFM-TV to also work hence the two antenna's.
Damon459 is offline   Reply With Quote
