The Tvfool report is not showing any antenna height above ground.
Do not delete the tvfool report that is not showing any antenna height above ground.
To see Tv signal strength improvements at higher antenna height , please make and post a tvfool report with the antenna height at 25 feet above ground.
25 feet antenna height above ground is a Reference antenna height above ground that gives a good idea of the Tv stations/channels that can be reliably received.
