Old 21-May-2014, 8:33 AM   #8
The second Tvfool Report has Important Differences.
Concerning the Digital Broadcast Tv Stations/Channels and Networks , in the Green and Yellow Reception Zones of the Tvfool Report.
The Digital Broadcast Tv Stations and Networks of the , North West Group , and the , ~West~ Group , Are The Same.
The , North West Group , is All UHF Tv Channels and the North West Group is All LOS=Line Of Sight Reception.
LOS is easier to receive then 1 and 2 Edge Path Obstructions Tv Stations of the ~West~ Group.
I recommend receive the , North West Group of All UHF Channels Tv Stations in the Yellow Reception Zone.
Install a , Antennas Direct , DB8e , UHF Channels 14 thru 51 antenna.
Buy the , DB8e antenna , at http://www.amazon.com
Aim the DB8e antenna at about 344 degree magnetic compass direction.
Use a Real and Actual Magnetic Compass to aim antenna , do not trust a cell phone or tablet compass and etc. compass.
A antenna system amplifier will most likely not be required for , 1 , 2 , 3 , Tv's connected.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
Install the , ronard(911) , 5 foot tripod antenna mount.
Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe.
Low price of about 10 dollars.
As always , obstructions in the direction of reception will disrupt reception.
Avoid Obstructions in the direction of reception such as and not limited to , roof , building , trees and tree leaves , plants and plant leaves , and any and all other obstructions.
Last edited by teleview; 22-May-2014 at 1:27 AM. Reason: Clarify information and typos.
