Old 21-May-2014, 3:13 AM   #6
Two Bears
OK ... here is the new report. I think you're all asking for the same thing, if not let me know.
http://www.tvfool.com/?option=com_wr...e1c6284db3f4be
GroundUrMast: Thanks for the recommendation. Would you still recommend this with the new plot? Is there an alternative to the Antennas Direct DB8E?
Although this looks like it gets great reviews on Amazon, even with some attic installations, it kinda looks like, well, for lack of a better description, a giant fly swatter. Is there a boom type antenna available with equivalent specs that you could recommend? Also, with the Antennacraft Y10713, is this additional antenna just to receive channel W18BN? What is this channel?
Looking at the RCA TVPRAMP1R preamplifier, does this also require a power supply to it while mounted on the mast?
Jake V: Wouldn't you point to the main towers rather than the translators? Do you know what the W18BN channel is? It seems like people report that they receive like 20-30+ stations after hooking up their antenna's, but there seems to be only about 8 or so main stations (ABC, NBC, CBS, FOX, PBS, ION, WB, IND). Are they getting duplicate stations in other languages?
Teleview: The pointer was only about a half a mile off to the north from the original plot? What would you recommend with this new plot?
BTW ... thanks to all of you for the quick replies. I am so glad I found this site, and appreciate all of your help very much.
Two Bears is offline   Reply With Quote
