Old 20-May-2014, 9:49 PM   #5
WeAreNotAlone
Originally Posted by teleview View Post
To receive More Digital Broadcast Tv Stations/Channels.
That also includes , WRTD-LD , Real UHF channel 46.
http://en.wikipedia.org/wiki/Luken_Communications.
Install a , Antennas Direct , DB8e , Real UHF channels 14 thru 51 antenna.
Aim 1 panel at about 251 degree magnetic compass to receive , WRTD-LD , Real UHF channel 46.
Aim the other panel at about , 47 degree magnetic compass direction to receive the Real UHF channels to the , North East.
Buy the , DB8e antenna at , http://www.amazon.com.
Also install a , http://www.antennacraft.net.
CS600 , VHF Channels 2 thru 13 antenna aimed at about 58 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a cell phone or tablet compass and etc. .
Install a , http://antennacraft.net.
10G221 preamp.
The , DB8e , UHF antenna will be connected to the UHF connection of the preamp.
The , CS600 , VHF antenna will be connected to the VHF connection of the preamp.
Fo 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Here are some and not all above the roof antenna mounts.
http://www.ronard.com34424560.html.
Home Depot has , 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe , the price is low at about 10 dollars.
Install the CS600 about 3 feet below the DB8e on the same mast pipe.
As a always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building in the directions of reception.
~snip~
The Best Practice for Reliable Reception is to install the antennas at a location that has the Least Amount to No Amount of Obstructions of Any Type or Kind in the directions of reception including your own roof and building.
Thank you for the links and the info.
I like the idea of using antenna's specific to frequencies they target. Also like the adjustable panels of the (UHF) Antennas Direct , DB8e.
While I understand mounting antenna(s) in "Free Air" is most desirable this weekend I was briefly able to get up into the attic on the "3rd" story of the house. (Approx 30ft from ground level)
Based upon the numbers you are seeing in the TV fool report, is there any chance antenna's being mounted within the protective shell of the roof would work well?
Roof=Conventional construction, 2x8 joists, plywood or OSB decking, asphalt shingles.
(50% in signal reduction, right?)
WeAreNotAlone is offline   Reply With Quote
