The DB8E would be more antenna than needed, primarily in terms of cost.
The CM-3000HD is also less than ideal in terms of cost.
I agree with the suggestions offered by tomfoolery... The HBU-11, HBU-22 and ANT-751 are good matches in your situation. An attic install may work. If not, these antennas should do quite well outside, clear of the obstruction produced by the building materials.
