Old 20-May-2014, 9:02 PM   #17
The TVPRAMP1R is supplied with a separate power supply which is intended for installation in an area that's dry. The amplifier unit is weather proof so it can be installed on the mast, near the antenna like any other preamplifier.
As I recall, my Y10713 was not supplied with a matching transformer (balun). The antenna output is '300Ω balanced', so you will need to use a standard 300Ω/75Ω matching transformer.
