Right now I'm considering the CM-3000HD Smartenna set-up in the attic. Will possibly add a preamp if needed.
Would a Db8e be overkill?
Anyone has input regarding these antenna models in this setup?
I'm not going to lie I'm a bit confused with my choices.
If I can pull off an attic install (even if it needs a pre-amp) it'll be better for our house, but I'm not closed to a roof install either.
