Old 20-May-2014, 9:59 AM   #1
Two Bears
What antenna/equipment needed for cabin in the Pocono Mts. of NEPA?
New to OTA and could use a little (lotta) help.
I have a cabin in the Pocono Mts. of NEPA and would like to receive the basic
channels ABC, NBC, CBS, FOX. Anything else would exceed my expectations.
The cabin is about 1800 ft. above sea level, with the top of the mountain being at about 1850 ft. The nearest towers appear to be about 23-36 miles away in the Wilkes-Barre/Scranton area. The cabin is located in a state park with about 26K acres of state forest behind me ... lots of trees!
Somewhere along my learning journey I came across a terrain elevation and there appears to be no other mountains, obstructions, etc. between the cabin and the towers ... just a lot of trees.
I'm assuming an attic installation won't work well, being a single story with an attic, but I can mount on the roof peak at about 20-25 feet in height.
What antenna/other equipment would you recommend?
TV signal analysis report:
http://www.tvfool.com/?option=com_wr...e1c6f590d8563b
Thanks in advance, and I'm sure more questions to follow.
Two Bears is offline   Reply With Quote
