Old 20-May-2014, 8:44 AM   #4
Install a , Antennas Direct , DB8e , Current UHF channels 14 thru 51 antenna aimed at about 288 degree magnetic compass direction.
Buy from , http://www.amazon.com.
Install a , http://www.antennacraft.net.
Y10-7-13 VHF high band channels 7 thru 13 antenna.
Aimed at about 280 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a cell phone or tablet and etc. compass.
10G221 preamp.
Connect the DB8e antenna to the UHF connection of the preamp.
Connect the Y10-7-13 antenna to the VHF connection of the preamp.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
For reception of , WBXX-DT , Real UHF Channel 20 , (virt) virtual number (20.1) , The CW.
Install a , Separate Antenna System , coaxes and HFS splitters , that go to each Tv location.
Install a DB8e antenna aimed at about 90 degree magnetic compass direction.
Install a Antenna Craft , 10G201 preamp.
A Tuner will be at each Tv location that is to receive , The CW.
http://www.epvision.com
Last edited by teleview; 21-May-2014 at 8:53 AM. Reason: Clarify information and typos.
