Old 20-May-2014, 3:36 AM   #2
Flint Ridge
Junior Member Wannabe
That is going to be tough. What channels are you wanting? Have you tried the TVFool from different heights? Say adding another 10 - 20'?
What CM amp do you have? How many tv's are you expecting to run?
Antennas Direct DB8e Extended Long Range UHF HDTV TV Bowtie Antenna (DB8e). That is UHF only. But if you can get it to pull in you should get most the main networks. If the CM amp does not do it, you might look at a low noise amp. Then all new coax, with compression fittings. How long a run of coax are you looking at? RG6 is the minimal quality.
