Old 19-May-2014, 10:52 PM   #4
cspartan
Originally Posted by dmfdmf View Post
This was the big clue. These tuners are not as sensitive as the Vizio tuner and RG6 coax has about 5dB loss per 100ft in the UHF channels but only ~2dB loss per 100ft in the VHF channels which is why the RCH9 and RCH11 survive the trip from antenna. So the bottom line is you need a pre-amp or a distribution amp but I'll leave that to others to make a recommendation. My own thought is a pre-amp would be overloaded so close to the antenna but a distribution amp may not have enough quality signal to amplify after the 100ft run of coax or add too much noise. Perhaps someone with more expertise in this area can advise.
Can anyone else weigh in on the pre-amp vs distribution amp? I could pick up the RCA TVPRAMP1R OR the Channel Master CM 3410 before or after the splitter.
cspartan is offline   Reply With Quote
