Old 19-May-2014, 6:19 PM   #12
BFDTerry
Would the fact that I am using screw on coax fittings be a possible cause? I have heard that compression fittings are preferred. I will go through my connections again. There shouldn't back any issue with the antenna signal following the same path that my cable signal used? A splitter is a splitter whether it be cable or antenna signal? And thank you for the prompt help!
BFDTerry is offline   Reply With Quote
