Old 19-May-2014, 6:13 PM   #11
Originally Posted by BFDTerry View Post
I did switch the TV's to antenna and performed a channel scan on them. Furthermore the TV that I did the initial scan successfully was moved back upstairs to its normal spot and hooked back into its normal coax jack and was unable to broadcast any of the already found channels.
That sound like a bad connection or a mistake wiring. You signals are so strong a distribution amp is not needed, even with multiple splitters.
