Old 8-Dec-2010, 12:14 PM   #1
John Candle
Tv Antenna Towers
Here is push up and collapsable square tubing , one square tube fits inside the other. Use as a Tv antenna tower with guy wires. http://www.alliedtube.com/sign-suppo...par-square.asp , http://www.alliedtube.com/pdf/Uni_Telespar.pdf . And with a little creative thinking , make a swing hinge mount and base plate , so that when sections are all collapsed down it can be laid over and do the antenna mounting while standing flat footed on the ground.
